When the thumb reaches the maximum indicator disappears.
Regards, Lello
Hello Lello,
I am just checking if you can isolate this in a sample, we can use for reproducing the issue, and if this is still actually an issue you require assistance with.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hi Lello,
Is it possible to supply me with a simple example, where the issue is reproducible/visible, because I'm still unable to duplicate it.
Tania
Hi Tania,
This problem occurs when the xamNumericSlider was inside RibbonWindowContentHost.StatusBar in the Ribbon Window
I can't reproduce this problem.Will you please supply more details how to reproduce it.
