180
Secondary Y axis, major gridline matching...
When adding a secondary Y axis, I notice that the major gridlines on 2nd Y axis sometimes does not match up to the Primary Y axis major gridlines. When this happens, the labels look offset, and I was looking for a way to correct this.
Is the only way to correct this is to set Autorange to False and manually set my min/maximum and units for both Primary and Secondary so that they have the same number of major gridlines?
Thanks in advance.
  • 138253
    I believe you are right and that other community members may benefit from this answer as well.
  • 375
    From what I have determined, through trial and error, you are correct in your assessment.  The only way to correct this is to make sure that both of your Axes have the same number of gridlines.
