I find the text size in XamDataGrid is smaller than in Word with the same font size and same font family. For example:"Segoe UI", 12:
Hello ,
I am just checking the progress of this issue and if you need any clarifications on the matter.
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
The reason for this difference is that WPF uses pixels as its default unit for font size, as in Word they are points. The mapping between the two of them is 1pt = (96/72) px.
You can find this simple conversion function useful:
public static double PointsToPixels(double points){ return points*(96.0/72.0);}
Sincerely,
Horen Kirazyan
