I want to hide the the row header of xamdatagrid not the column Header.
Thanks. Your solution solved my issue.
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
Hello jama64,
I have been looking into this for you and assume you are referring to the RecordSelectors which you can disable by setting this in the FieldLayoutSettings of the XamDataGrid like so:
<igDP:FieldLayoutSettings RecordSelectorLocation="None" …
Please let me know if you require any further assistance on the matter.
Sincerely,
Petar Monov
