40
ContentPane activation order issue
I'm having the following problem:
1) I dock together two floating panes (one at the top, one at the bottom)
2) I click on the bottom pane: bottom pane is activated, top pane is deactivated
3) I click on a third pane: top and bottom pane are deactivated
4) I click on the top pane: Bottom pane is first activated, then top pane is activated. Top pane should be activated directly but since it is docked together with another pane that was previously active, it is somehow not.
It is not a major issue for us but it generates polluting activation and deactivation event.
Is this a normal behavior ? Is there a way to prevent such unwanted pane activation/deactivation events?
