I have a content pane with a xamdatagrid as content. One of the columns in the grid is a button that opens a popup that allows a user to edit some information that is not displayed in the grid. When the user clicks in a textbox in the popup, the unpinnedcontentpane flys in. How do I prevent this? I tried wiring to executingcommand to cancel the flying, but this does not always fire. Thanks!
HI,
Maintaining the postion of the ContentPanes in the unpinned area , when a ContentPane is pinned and unpinned, is not currently supported.
This request has been submitted as a feature request.
Sincerely, Matt Developer Support Engineer
Thank you. In the meantime, is there a workaround to reposition a tab after the corresponding unpinned tab flyout is unpinned?
HI ,
I will submit a feature request for the following:
1) maintain the position of the pane in the unpinned area when the pane is pinned and unpinned
2) suppressing the flyin
Hi Matt,
When I run the sample you provided and click on the button, the messagebox is displayed, and then the flyout closes. This is the behavior I would like to prevent. The pane autohides, but I cannot find a way to prevent it from auto hiding until I'm done with the popup.
Question 1: I do not want to pin the flyout pane as a workaround. If I do, and then unpin it, the tab changes position to the end of the tab collection. Is there a way to prevent that from happening? This is a problem in general - the tab should remain in the same position when it is unpinned.
Question 2: If I wire to the ExecutingCommand event, it is not fired when the flyout pane auto hides, thus I cannot prevent the flyout from closing using commands. I cannot find another event that fires when the pane auto hides. Is there a property or event I can use to intercept the flying when I want?
I am attaching a sample application that will make the Pane Flyout during the button click.
I am using the ContentPane's ExecuteCommand method and passing it the Flyout command.
I also set the XamDockManager's FlyoutAnimation to Fade.
Here a help link to the ContentPaneCommands. http://help.infragistics.com/NetAdvantage/WPF/2010.3/CLR4.0/?page=InfragisticsWPF4.DockManager.v10.3~Infragistics.Windows.DockManager.ContentPaneCommands_members.html
