I have a Grid, some Fields in the Grid have custom validation which are set in the FieldLayout. For the beginning i will edit a cell, and set a new value for example -4 In the EditModeEnding EventHandler i check the value, but i couldn´t set the HasDataError because it is a readonly property.
What is the best way to validate a specific Field and color the background with a color ?In the Feature Browser there is an example Data Error Styling, that is the behaviour which i will implement. But in the example the DataSource implements some interfaces and in my case, i have no DataSource which implements this interface.
XAML.
<my:Field Name="Name" Label="Name"> </my:Field> <my:Field Name="value" Label="value"> </my:Field>
<igDP:FieldLayoutSettings SupportDataErrorInfo="RecordsAndCells" DataErrorDisplayMode="ErrorIconAndHighlight" />
Codebehind:
void xamDataPresenter1_EditModeEnding(object sender, EditModeEndingEventArgs e) { if (e.Cell.Field.Label.Equals("man")) { int value; if (!Int32.TryParse(e.Editor.Text, out value)) { e.AcceptChanges = false; string val = e.Cell.Value.ToString(); MessageBox.Show("Data Validation Failed. Must enter an Integer: " + val); e.Cancel = true; } else { if(value < 0) { // e.Cell.HasDataError TODO !!! How to set this cell ?? e.Cancel = true;
// TODO: assign this cell with a different style -> RED Background e.Cell.DataPresenter.FieldSettings.CellValuePresenterStyle = GetLabelStyle(System.Windows.Media.Brushes.Red, true);
else { //assign different style -> GREENBackground
The next step, how to set the cell the Backgrounds programmatically (GREEN, RED)
In the examples i have seen a DataSource Class which implements the IDataErrorInfo. In my project we have Bound all Fields manually in the grid. i have no IDataErrorInfo implemented, because i haven´t got a BusinessClass. how to use this functionality without IDataErrorInfo in my project?
Hello.
If you don't want to implement IDataErrorInfo, then the easiest way to enforce validation is to use a ValueConstraint on the cells editor. For example, let's say that you have a UnitCost field of type decimal and you don't want the user to be able to enter a cost that is less than zero. You can create a ValueConstraint on the editor which will prevent the user from ever being able to enter invalid data in the first place.
When you do this, you cannot enter a value that is less than zero. You also cannot enter any alpha characters; only numeric entry is allowed. This is because the EditAsType property on the UnitCost field is set to sys:decimal.
Using a ValueConstraint negates the need to handle EditModeEnding and display a message box telling the user to enter a number. You're guaranteed to get valid data every time with this method with a less code.
igDP:Field Name="UnitCost" Label="Unit Cost">
<igDP:Field.Settings>
<igDP:FieldSettings
EditorType="{x:Type igEditors:XamNumericEditor}"
EditorStyle="{StaticResource UnitCostEditorStyle}"
EditAsType="{x:Type sys:Decimal}"/>
</igDP:Field.Settings>
</igDP:Field>
Style x:Key="UnitCostEditorStyle" TargetType="{x:Type igEditors:XamNumericEditor}">
<Setter Property="Format" Value="$###,##0.00;($###,##0.00)"/>
<Setter Property="ValueConstraint">
<Setter.Value>
<igEditors:ValueConstraint MinInclusive="0.00"/>
</Setter.Value>
</Setter>
</Style>
Sincerely,CharlieSenior Developer Support EngineerMCTS
