340
Different LabelPresenter between XamDataGrid and FieldChooser
I try to define different labelpresenter styles between Xamdatagrid and FieldChooser.
I definde those two styles:
    <Style TargetType="{x:Type igDP:LabelPresenter}">
        <Setter Property="Background" Value="#FF000000"/>
        <Setter Property="Foreground" Value="#FFFFFFFF"/>
        <Setter Property="LabelHighlight" Value="{StaticResource LabelHLight}"/>
        <Setter Property="FontFamily" Value="Calibri"/>
        <Setter Property="FontSize" Value="14"/>
        <Setter Property="HorizontalContentAlignment" Value="Center"/>
     </Style>
    <Style x:Key="forFieldChooser" TargetType="{x:Type igDP:LabelPresenter}">
        <Setter Property="Background" Value="#FFFFFFFF"/>
        <Setter Property="Foreground" Value="#FF000000"/>
    </Style>
I did not find how to apply the second one to the fieldchooser so i tried to define it as default (by removing the keyword "x:key=forFieldChooser"), and renamed the first one "forHeader" then I  applied it to my datagridthis way:
<igDP:XamDataGrid.FieldSettings>
                <igDP:FieldSettings LabelPresenterStyle={DynamicResource forHeader}/>
</igDP:XamDataGrid.FieldSettings>
It worked fine for the headr but the fieldchooser also took this style instead of default.
Is there anyway to use different styles between Fieldchooser and Datagrid's headers?
