I have a data structure to represent an option flag structure.
public class Flag { public string Name { get; set; } public bool Value { get; set; } private bool isChecked; public bool IsChecked { get { return isChecked; } set { isChecked = value; Parent.Update();} } public Flags Parent { get; set; } public Flag() {} }
This will be a dynamic field on a XamGrid where each row will have different options as part of the row data item. First I am trying to get it working on its own before I use it with a xamGrid.
I am using a XamComboEditor with a data template to display checkbox with each item.
<igEditor:XamComboEditor IsAlwaysInEditMode="True" Name="TestFlagsCombo" ItemsSource="{Binding TestFlags}" DisplayMemberPath="{Binding Parent.Selected, Mode=OneWay}"> <igEditor:XamComboEditor.Resources> <DataTemplate DataType="{x:Type local:Flag}"> <StackPanel Orientation="Horizontal"> <CheckBox IsChecked="{Binding Path=IsChecked}" VerticalAlignment="Center" /> <TextBox Margin="4" Text="{Binding Path=Name}" VerticalAlignment="Center" /> </StackPanel> </DataTemplate> </igEditor:XamComboEditor.Resources> </igEditor:XamComboEditor>
So far the combo box displays the items in TestFlags, which is a class derived from ObservableCollection. What I want is for the ComboBox display text to show a string indicating what options have been selected. for example "Item1|Item3|Item4" would mean 3 items selected. One method I have tried is to give each Flag a reference to the collection "Parent", which has a Selected Property which is updated to the string representation of all IsChecked Flags. This is all working. What I cant get is the combo DisplayText to bind to this Selected property. I have tried
DisplayMemberPath="{Binding Parent.Selected}" as Parent is a property on Flag pointing back to the Collection to access the Selected property that I want to display.
Is there a way I can achieve this or is there a better solution to what I'm trying to do? Here is the Flags class to complete the source.
public class Flags : ObservableCollection<Flag> { private string selected; public string Selected { get { return selected; } set { selected = value; OnPropertyChanged(new PropertyChangedEventArgs("Selected")); } } public Flags() {} public void Update() { StringBuilder sb = new StringBuilder(); this.Where(x => x.IsChecked).Select(x=> x.Name).Run(s => sb.Append(s).Append("|")); if (sb.Length > 0) sb.Remove(sb.Length - 1, 1); Selected = sb.ToString(); } protected override void InsertItem(int index, Flag item) { item.Parent = this; base.InsertItem(index, item); } }
This helped me with my issue thanks.
This solution works well but how would one implement this on the cell of xamDataGrid ? I need an option dropdown menu to select flag type options in the cell of a xamDataGrid.
Once selected the value of the options would be displayed in the cell as above.
I know i can use an adorner to but a combobox dropdown of all options would be far slicker.
I'm sorry for late reply.
Look at the attached project. I implement the behavior that you want.
Tell me if you need more help or you have any questions.
Anastas
