2395
Field Chooser
Two questions:
1. I don't want field chooser button to be visible, but want to invoke field chooser from context menu.
2. I would like to hide a record selector (only data fields to be visible)
Is above possible and if it is, how?
Thank you
  • 3520
    Verified Answer
    Hi Dierk,
    1. If you don't want to use the FieldChooserButton, you can invoke the FieldChooser in 2 ways:
    - By using ShowFieldChooser command as follows:
    xamDataGrid1.ExecuteCommand(DataPresenterCommans.ShowFieldChooser);
    - By using ShowFieldChooser method as follows:
    xamDataGrid1.ShowFieldChooser();
    2. In order to hide the record selector you can set the RecordSelectorLocation property of FieldLayoutSettings to None.
    Hope this helps.
