65
XamDockManager Cal Floating Tab Region Error
I have a XamTabControl that I marked as a region with CAL.
This is nested inside a XamDockManager. Everything shows up fine and I am able to add view to the tab control region as long as it is docked. However, I get a region not found error when I undock the tabcontrol and try to add a view.
I ran across this forum post http://blogs.infragistics.com/forums/t/26275.aspx suggesting that using version 9.1 of the controls solves the problems but that did not work for me.
Are there any other suggestions?
  • 17559
    Hello Kasanova12,
    It has been a while since you have made your  post, in case you still need of support I will be glad to assist you on the matter. I suppose the other community members can benefit from this answer as well.  So I was reviewing your issue and I can suggest you take a look at the following forum thread which concerns similar topic:
    http://news.infragistics.com/forums/p/29771/171555.aspx .
    If you still need any additional assistance on this, please do not hesitate to ask.
