645
Suppress ToolTip when handling mouse enter event
In this question: http://forums.infragistics.com/forums/t/49255.aspx Graham provided a good solution to the situation where points overlapped on a mouse click by popping up a control to display the points.
Now, looking a bit further at the situation, I'd like to perform the same sort of thing when doing a mouseover on the series. To handle this, I handled the series MouseEnter event, grabbed the current mouse position, computed the X and Y offset of the series, adjusted the mouse position for that offset and used that position to determine what points were under the mouse (or close to it). Something like this:
Point point = Mouse.GetPosition(xamDataChart1);
double diffW = xamDataChart1.ActualWidth - e.Series.ActualWidth;
double diffH = xamDataChart1.ActualHeight - e.Series.ActualHeight;
point.X = point.X - diffW;
point.Y = point.Y - diffH;
// basically do GetHitHitems except pass in point rather than e.Item.
This works swimmingly well except that sometimes I get the ToolTip for one of the overlapping points popping up rather than my own Popup listing the points.
Any ideas how to avoid this happening?
