Is there an event for column width change and row height change?
Hello ,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
I have been looking into your issue and I what you can do is create styles for the LabelPresenter and DataRecordPresenter with EventSetters for the SizeChanged event like so:
<Style TargetType="{x:Type igDP:DataRecordPresenter}" >
<EventSetter Event="SizeChanged" Handler="DataRecordPresenterSizeChanged" />
</Style>
<Style TargetType="{x:Type igDP:LabelPresenter}" >
<EventSetter Event="SizeChanged" Handler="LabelPresenterSizeChanged" />
and here are the event handlers they go with:
void LabelPresenterSizeChanged(object sender, SizeChangedEventArgs e)
void DataRecordPresenterSizeChanged(object sender, SizeChangedEventArgs e)
Please let me know if you require any further assistance on the matter.
Sincerely,
Petar Monov
