Hi
I am using xamdataGrid & binding the DataView as a DataSource to grid. if cell value changed
from original value I want to show the forground color of cell in Green. In Winforms there used to be
onDrawmethods on any grid where we used to change the color.
I tried using DataValueChanged event but if I sort on the column color will be applied to diff records
Pls help me with this
-Kiran
Hi Kiran,
I was wondering if you were able to have a look at this or if it is still an issue?
Regards Petar.
I see, I will follow the thread and wait for the updated sample.
Hi Kiran Guptha,
Try to use property RecordContainerGenerationMode and set the value as Virtualize hope this will address the issue. If not then please let me know.
The issue still existis. I didn't get chance to update the example.. I pormise I will send it soon.
Hello Kiran,
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
