20
setting Column width of XamDataGrid in XAML
I want to set the Column width of XamDataGrid in XAML. There is no Width Property available like
<ip:Field Label="Name" ........... Width="60"/>
Here is my sample code.
 <ip:XamDataGrid Name="PatientsList" DataSource="{Binding PatientsList}" SelectedItemsChanged="PatientsListSelectedItemsChanged"
XamDataGridBehaviours:XamDataGridBehavior.IsSynchronizedWithCurrentItem="True" GroupByAreaLocation="None">
<ip:XamDataGrid.FieldLayoutSettings>
<ip:FieldLayoutSettings AutoGenerateFields="False" SelectionTypeRecord="Extended" MaxSelectedRecords="1"/>
</ip:XamDataGrid.FieldLayoutSettings>
<ip:XamDataGrid.FieldSettings>
<ip:FieldSettings AllowEdit="False" CellClickAction="SelectRecord"/>
</ip:XamDataGrid.FieldSettings>
<ip:XamDataGrid.FieldLayouts>
<ip:FieldLayout>
<ip:FieldLayout.Fields>
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colSex}}" Name="Sex"/>
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colPatientId}}" Name="PatientId"/>
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colLastName}}" Name="LastName" />
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colFirstName}}" Name="FirstName" />
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colPatientId}}" Name="FullName" />
<ip:Field Label="{Binding Source={x:Static properties:Resources.StudyManager_colDOB}}" Name="DateOfBirth" />
</ip:FieldLayout.Fields>
</ip:FieldLayout>
</ip:XamDataGrid.FieldLayouts>
</ip:XamDataGrid>
  • 2677
    Im not sure why you cant see a width property.  There should be one in there in the Field object.
     <igDP:Field Name="Column_1" Label="Column_1" Width="150"/>
    If you still have this issue, pleas let me know.  If I have misunderstood your question, please let me know.
