Hi. I need some help please.I'm new to Infragistics.I'm trying to add columns in xamdatagrid, but it doesn't work..<igDP:XamDataGrid Name="xamDataGrid1" BindToSampleData="False"> <igDP:XamDataGrid.FieldLayouts> <igDP:FieldLayout> <igDP:Field Label="Первый" Name="nFirst" Width="40" /> <igDP:Field Column="1" IsPrimary="True" Label="Второй" Name="nSecond" Width="50" /> </igDP:FieldLayout> </igDP:XamDataGrid.FieldLayouts> </igDP:XamDataGrid>when i compile my program, in xamdatagrid is nothing..But if I write "<igDP:XamDataGrid Name="xamDataGrid1" BindToSampleData="True">", in xamdatagrid i can see my columns and columns, which given for example..please, help me.p.s. sorry for my english
Hi Benjamin,
I am really glad I could help you out. If you don’t have any additional questions regarding this, please verify the thread as answered so it helps other users as well.
Thanks in advance.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hi, Petar,Thank you very much. I did everything that I wanted by your example.Regards Benjamin.
I have been further looking into your issue and have created a sample project showing how you can do this. Please run it and let me know if this is what you needed. Let me know if you require any furher assistance on the matter.
Regards Petar.
Hello,Yes, you understood me correctly.
When users fill up the grid, data record in database. Then, the grid, based on database, fills up or remains empty.Sincerely, Benjamin.
Hello ,
I think I might have misunderstood you. Just to make sure we are on the same side – are you trying to have an empty grid and the allow the users to fill it up?
Looking forward to your reply.
