I noticed FieldChooser allow to drag fields and drop to grid to move columns around.
Currently is it possible to drag and drop inside the fieldchooser itself to move the fields around and so it updates the grid based on the drop position?
Muthu
Hello Muthu,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through your post and I can say that the FieldChooser is made to control the Visibility of the Fields in the XamDataGrid. You can set the Fields in FieldChooser to be ordered like they are in the XamDataGrid, but you are not able to determine their position in the it from the FieldChooser.
