Hi all,
I am currently trying to archive something that I was used to do with the UltraWinGrid before.
Basically I have a DataTable that contains a BitmapImage column which is bound to a xamDataPresenter.
As expected the image is shown, even with the correct size which I have set right after the FieldLayoutInitialized event fired.
What I want to see in the cell is the image (24x24) a little space and a little button that allows me to fire a "select image" dialog.
Problem here is that the DataTable is generated in code and the columns may change all the time, so I have to do that in code.
Could anybody please point out how to archive this?Any help is kindly appreciated,
best regards
Andy
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through your post and I created a sample project for you. I basically create a Style for the CellValuePresenter, in which I set the ContentTemplate property properly, so that it has an Image and a Button as you want.
