90
Datagrid overflows layout on 64 bit systems
we currently face the problem, that the datagrid doesn´t recognize the available space for it on 64 bit systems and overflows the layout without scrollbars.
You find screenshots attached, how it should be (and is on 32bit systems) --> 32bit.jpg (attached to next post) and how it is on 64bit systems --> 64bit.jpg
Following you find the corresponding code for the datagrid.
<UserControl x:Class="JVS.View.DataGrids.DataGridErlegung"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:igDP="http://infragistics.com/DataPresenter"
    xmlns:igEditors="http://infragistics.com/Editors"
    xmlns:PresentationOptions="http://schemas.microsoft.com/winfx/2006/xaml/presentation/options">
    <DockPanel Name="dp" Width="Auto" Height="Auto">
        <igDP:XamDataGrid DockPanel.Dock="Top" Height="Auto" Margin="0" Name="dgErlegung" Width="Auto" Theme="Onyx" GroupByAreaStyle="{StaticResource ResourceKey=MyCustomGroupByArea}">
            <igDP:XamDataGrid.Resources>
                <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="WrapField">
                    <Setter Property="Template">
                        <Setter.Value>
                            <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                                <TextBlock Margin="{TemplateBinding Padding}"
                        Width="{TemplateBinding Width}"
                        Height="{TemplateBinding Height}"
                        Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Content}"
                        TextWrapping="Wrap"
                        Background="Transparent"
                        HorizontalAlignment="Left"
                        VerticalAlignment="Center" />
                            </ControlTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
            </igDP:XamDataGrid.Resources>
            <igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:FieldLayoutSettings AutoGenerateFields="False" AllowAddNew="False" AllowDelete="False">
                </igDP:FieldLayoutSettings>
            </igDP:XamDataGrid.FieldLayoutSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout>
                    <igDP:FieldLayout.Fields>
                        <igDP:Field Name="Wildart" Label="Wildart">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings AllowEdit="False" AllowResize="True" />
                            </igDP:Field.Settings>
                        </igDP:Field>
                        <igDP:Field Name="Revier" Label="Revier">
                                <igDP:FieldSettings AllowEdit="False" AllowResize="True"/>
                        </igDP:Field>
                        <igDP:Field Name="Erlegungsdatum" Label="Erlegungsdatum">
                        </igDP:Field>
                        <igDP:Field Name="Hochsitz" Label="Hochsitz">
                        </igDP:Field>
                        <igDP:Field Name="Erleger" Label="Erlegt von">
                        </igDP:Field>
                        <igDP:Field Name="Anzahl" Label="Anzahl">
                        </igDP:Field>
                        <igDP:Field Name="Bejagungsart" Label="Bejagungsart">
                        </igDP:Field>
                        <igDP:Field Name="Gewicht" Label="Gewicht">
                        </igDP:Field>
                        <igDP:Field Name="Alter" Label="Alter">
                        </igDP:Field>
                        <igDP:Field Name="Geschlecht" Label="Geschlecht">
                        </igDP:Field>
                        <igDP:Field Name="Waffe" Label="Waffe">
                        </igDP:Field>
                        <igDP:Field Name="Falle" Label="Falle">
                        </igDP:Field>
                        <igDP:Field Name="Schussentfernung" Label="Schussentfernung">
                        </igDP:Field>
                        <igDP:Field Name="Fluchtstrecke" Label="Fluchtstrecke">
                        </igDP:Field>
                        <igDP:Field Name="TrophLaenge" Label="Trophäenlänge">
                        </igDP:Field>
                        <igDP:Field Name="Trophgewicht" Label="Trophäengewicht">
                        </igDP:Field>
                        <igDP:Field Name="TrophNotiz" Label="Trophäennotiz">
                        </igDP:Field>
                        <igDP:Field Name="Treffersitz" Label="Treffersitz">
                        </igDP:Field>
                        <igDP:Field Name="Haematome" Label="Hämatome">
                        </igDP:Field>
                        <igDP:Field Name="VerlOrgane" Label="Verletzte Organe">
                        </igDP:Field>
                        <igDP:Field Name="Fallwild" Label="Fallwild">
                        </igDP:Field>
                        <igDP:Field Name="Todesursache" Label="Todesursache">
                        </igDP:Field>
                        <igDP:Field Name="Eigenverbrauch" Label="Eigenverbrauch">
                        </igDP:Field>
                        <igDP:Field Name="Erloes" Label="Erlös Wildbret">
                        </igDP:Field>
                        <igDP:Field Name="Bemerkung" Label="Bemerkung">
                                <igDP:FieldSettings AllowEdit="False" AllowResize="True" CellValuePresenterStyle="{StaticResource WrapField}" CellWidth="600"/>
                        </igDP:Field>
                    </igDP:FieldLayout.Fields>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
        <StackPanel DockPanel.Dock="Top" Background="White">
            <StackPanel Orientation="Horizontal" VerticalAlignment="Top" HorizontalAlignment="Center">
                <Button Name="btnNeu" Style="{StaticResource ButtonNeu}" Width="110">Erlegung anlegen</Button>
                <Button Name="btnExport" Style="{StaticResource ButtonNeu}" Width="90">Export Excel</Button>
                <Button Name="btnDrucken" Style="{StaticResource ButtonNeu}" Width="80">Drucken</Button>
            </StackPanel>
        </StackPanel>
    </DockPanel>
</UserControl>
With kind regards
Frank
