640
Problems using Unboundfield BindingMode.TwoWay. It only works 1 time.
Hi there,
we have a issue with multiple unboundfields in the XamDataGrid.
When using them, and setting the BindingMode on TwoWay it only updates the Cell or ObjectProperty once.
For example:
We have Length as a property of documentline. This is added to the grid as an UnboundField.
When adding or editing a documentline we change length from 1 to 4. This is correct and also changed. When we enter the Length field again and fill in for example 5 it changes back to 4 on exit of the field. Everything we have tried doesnt help. We are hoping you can help us.
This is the code we use to add a field to the XamDataGrid:
            UnboundField unboundField = new UnboundField();
            String fieldName = "Length";
            FieldLayout fieldLayout = null;
            unboundField.Visibility = visibility;
            if (unboundField.Visibility == Visibility.Hidden)
                return unboundField;
            //Always Disabeled!!! One way binding...
            if (bindingMode == BindingMode.OneWay)
                unboundField.Settings.AllowEdit = false;
            //If no FieldLayout exists create one...
            if (xamDataGrid.FieldLayouts.Count == 0)
                xamDataGrid.FieldLayouts.Add(new FieldLayout());
            if (xamDataGrid.FieldLayouts.Count > 0)
                fieldLayout = xamDataGrid.FieldLayouts[0];
            if (fieldLayout == null)
            fieldLayout.Settings.AutoGenerateFields = false;
            //Add field
            unboundField.Name = fieldName;
            unboundField.Label = ResourceManager.GetResourceStrByKeyLang(resourceAuthKey);
            unboundField.ToolTip = unboundField.Label;
            unboundField.Width = new FieldLength(fieldWitdh);
            unboundField.BindingPath = new PropertyPath(GetBindingFromResAuthKey(resourceAuthKey));
            unboundField.BindingMode = bindingMode;
            if (editorType != null)
                unboundField.Settings.EditorType = editorType;
            else
                unboundField.Settings.EditorType = typeof(XamTextEditor);
            fieldLayout.Fields.Add(unboundField);
