I'm trying to add an image for the label in the header for a field like the following:
<xam:UnboundField Name="HasAttachment"
DataType="{x:Type system:Int32}" BindingPath="HasAttachment"
Column="9" Row="0" RowSpan="2">
<xam:Field.Settings>
<xam:FieldSettings AllowHiding="Never" CellValuePresenterStyle="{StaticResource HasAttachmentCellStyle}" CellMaxWidth="35" LabelHeight="0"/>
</xam:Field.Settings>
<xam:UnboundField.Label>
<Image Source="../Resources/HasAttachment.png" Width="20" Height="20" />
</xam:UnboundField.Label>
</xam:UnboundField>
The problem is:
1) some images for some fields worked, and another fields throw this exception:
Specified element is already the logical child of another element. Disconnect it first.
2) I removed these fields which throw the exception and kept the only which work, but the export to excel doesn't work now.
Any help !!!
Thanks in advance
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through your post it seems like that it is a normal behavior and you are not able to the image from the LabelPresenter in an Excel sheet.
