When setting field visibility in code like this:
FieldLayouts[0].Fields["FieldName"].Visibility = Visibility.Collapsed;
FieldPositionChanged event isn't fired. When changing field visibility by using FieldChooser everything is OK.
Hi Anton,
It turns out this is the expected behavior for code execution following the Windows Forms pattern assuming that the developer can would know when this is executed and can respond accordingly. I can suggest simply calling the EventHandler method on your own right after you modify the FieldPosition or add a similar logic right after it.
Hope this makes things clearer. Please let me know if you require any further assistance on the matter.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
Hello Anton,
I have been further investigating your issue and have logged this with our development with ID: 59276. I have also created a support ticket (CAS-55987-2LQKRW) on your behalf in order to link the two together and you get automatically updated when a fix is available for downloading on our website.
Please let me know if I can be of any further assistance.
I have been looking into your issue and was able to reproduce the behavior you have described. I am going to forward it to our development team and get back to you as soon as I have a reply from them.
Thank you for pointing this out to us. I’ll update you shortly on our progress.
