I have created a sample app demo'ing 2 grids. 1 grid has the theme set in XAML.The other grid has the theme set in code behind. Both set the same theme office silver. However you can clearly see differences. The rows get truncated in height and the filter edit boxes simply do not appear. Please advise.
Chad
Matt,
I don't understand why it wouldn't compile, but OK. Maybe just run the exe without building it to see the issue then.
I have received the email about the open case ticket. However I am curious if this was opened because you did see the issue? Or not?
I can supply whatever info is needed.
HI,
I tried to build your project in VS2008, but it would not build. I brought your project up in Vs2010 and all was ok. I ran it using build 9.2.20092.2160. Every thing seemed to be ok.
I created a case for this issue and will send you an email.
Sincerely,
Matt Developer Support Engineer
I am really eager for a solution to this. Any advice will be greatly appreciated.
