490
Setting the xamDataGrid DataContext to an object
I want to set the DataContext of my grid to an object and use a collection of that objects as the grids data source.  It looks like I had no problem doing that but I have some questions about how the rows are generated for the grid.
I see that each public property of the object held in the collection is used as a column of the grid.  Does the column name have to be the same as the property name?  If not, how can  I change it?  Do I need to predefine the grids columns in xaml?  If I do that, how will the binding work?
If I want to set the column widths and am not defining them in xaml, which event should I be listening to so that I can set the column widths in code?
If there are any examples of binding to a collection of objects that would also be useful.
Thanks.
  • 2180
    Suggested Answer
    You can change the columns settings by defining the FieldLayout and the Fields in xaml like this:
    <igDP:XamDataGrid.FieldLayouts>
    <igDP:FieldLayout >
    <igDP:FieldLayout.Fields>
    <igDP:Field Name="passingyards" Label="Total Passing Yards" Width="200" />
    <igDP:Field Name="passingyardsperattempt" Label="Passing Yards/Attempt" />
    <igDP:Field Name="passingyardspergame" Label="Passing Yards/Game" />
    </igDP:FieldLayout.Fields>
    </igDP:FieldLayout>
    You can hook to XamDataGrid's Loaded event or FieldLayoutInitialized event using this code:
    xamDataGrid.FieldLayouts[0].Fields["passingyards"].Width = new FieldLength(200);
    Hope this helps.
    Diyan Dimitrov
