I have read the earlier post about save/load layout. I understand there's no built-in support so I had to use Save and Load Views provided in the feature browser as an example. I did that. I noticed the difference between using this approach and the built-in support coming from other Infragistics controls like XamDataGrid is the lack of support of serialization. E.g., to save and load views I use RowsHierarchy which is ObservableCollection<IHierarchy>. However, Hierarchy itself does not provide parameterless constructor and cannot be serialized to XML.
Is there a way to work with serialization? If not, is it going to be supported in a future release?
Yu
Todor,
Thanks for pointing to another post which is very useful. I am still working on it but I think that solution works for us at this moment.
Looking forward to including this feature in a future release.
Hi
You can look at this post for another example how to save/load view of pivot grid control. It is written for silverlight, but it will work and for WPF.
About implementing of save/load functionality as a feature in pivot grid, we have planned it for our future releases, but I can’t tell you if this will be in 11.1 or 11.2. For sure it will be not in 10.3 which is planned for October this year.
Regards
Todor
