I might be missing something, but is there a sample application that uses the xamTreemap? Just looking for a place to start.
Thanks.
The samples use sample data stored in XML files. Have you pointed the extracted code to the sample data?
Here is the file containing the data for the drilldown samle:
If this doesn't work, could you attach you code so we can see where the problem is.
Thanks,Nikolay
I only want to run one of the treemap samples,named DataDrilldown.I have no errors there,But I can't
show the datas in the page,I have got the datas in the cs file.I just copy the xaml code to my xaml file.
I want to know if i lost something I don't know.
Hello!
You can check out the online Silverlight samples which are hosted at http://labs.infragistics.com/silverlightdv/2010.2/ - at the top of the page you will see a list with all the Data Visualization controls. The xamTreemap control is on the right in the list.
You can also download and install the Data Visualization WPF samples:http://es.infragistics.com/dotnet/netadvantage/wpf/data-visualizationdownloads.aspx#Downloads. After you install the samples, you can open a samples browser and try out the xamTreemap control applications.
Also you can see the articles about the xamTreemap:
Silverlight - http://help.infragistics.com/NetAdvantage/DV/2010.2/CLR4.0/
WPF - http://help.infragistics.com/NetAdvantage/WPFDV/2010.2/CLR4.0/
The articles you are looking for are located in the table of contents under "Developer's Guide" > "Controls" > "xamTreemap".
If you have any questions about the xamTreemap control, don't hesitate to ask.
