HiI refer to another issue "Databound Grid adding $ character to random fields", where you wrote:"If you are using decimal or Currency, the grid will probably assume a currency format. Try setting the Format property on the column to something like "n" for number and that should remove the currency symbol."But I need to present weight values with up to 3 decimals, and need to use a decimal field.How do I "set up" the grid not assuming the decimal fild is a currency field, and not shox the $ char ?
brgdsJohn
HI,
I am just following up on this forum post.
If you need further assistance regarding this post, please feel free to contact me.
Sincerely MattDeveloper Support Engineer
Try changing the Default Editor types for decimal data.
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=xamData_Default_Editor_Types_for_Different_Data_Types.html
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=xamData_About_xamDataPresenter_and_xamEditors.html
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=xamEditors_Overview_of_the_ValueEditor_Class.html
You can change the default editor for a given type, for decimal its the xamcurrencyeditor you could change to the xamnumericeditor
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=InfragisticsWPF4.Editors.v10.2~Infragistics.Windows.Editors.ValueEditor~RegisterDefaultEditorForType.html
You can specify default mask for a data type using the xamMaskedEditor's RegisterDefaultMaskForType static method.
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=InfragisticsWPF4.Editors.v10.2~Infragistics.Windows.Editors.XamMaskedEditor~RegisterDefaultMaskForType.html
Sincerely,
Matt
