1065
How to change the label height in procedure code.
How could I change xamDataGrid label height in procedure code?
I tried the below code, but it didn't work.
Private Sub GridInfragistics_Loaded(ByVal sender As Object, ByVal e As System.Windows.RoutedEventArgs) Handles Me.Loaded
        'ColumnHeaderHeight is a dependency property of the GridInfragistics user control and it is greater than 0
        If ColumnHeaderHeight > 0 Then
            Dim labelPresenter As LabelPresenter = TryCast(Infragistics.Windows.Utilities.GetDescendantFromType(grdTable, GetType(LabelPresenter), False), LabelPresenter)
            If labelPresenter IsNot Nothing Then
                Dim labelParent As DependencyObject = labelPresenter.Parent
                Dim count As Integer = VisualTreeHelper.GetChildrenCount(labelParent)
                For i As Integer = 0 To count - 1
                    Dim child As LabelPresenter = TryCast(VisualTreeHelper.GetChild(labelParent, i), LabelPresenter)
                    If child IsNot Nothing Then
                        child.Height = ColumnHeaderHeight
                    End If
                Next
            End If
        End If
End Sub
Is there any easy way to change labe height?
Thanks.
