714
Invalid slider values and thumb-tick alignment problem
I've configured a slider in order to select a value between ZERO and ONE which can have maximum 2-digit after ZERO.  I've attached a sample project and a video in order to explain my problems:
1. I didn't change the original thumb style but still the ticks and the thumb's arrow doesn't align correctly. There is a slight difference. May be it's because of my tick configuration. Can you check it out?
2. Second problem is a weird one: As you can see in the video I bind a TextBox to the thumbs Value property in order to show the current value. But after 0.8 it starts to show values like 0.8400000000000001.
Can you check out the sample project? May be my configurations are wrong.
Thanks in advance
SliderError.zip
