I am trying to hide cloumn from field chooser. Its working fine but if you move field from out of grid view then system throughing this exception:
Message : "'selectorArrow_Active' name cannot be found in the name scope of 'System.Windows.Controls.ControlTemplate'."
Source:"PresentationFramework" and this is the stack trace.
at System.Windows.Media.Animation.Storyboard.ResolveTargetName(String targetName, INameScope nameScope, DependencyObject element) at System.Windows.Media.Animation.Storyboard.ClockTreeWalkRecursive(Clock currentClock, DependencyObject containingObject, INameScope nameScope, DependencyObject parentObject, String parentObjectName, PropertyPath parentPropertyPath, HandoffBehavior handoffBehavior, HybridDictionary clockMappings, Int64 layer) at System.Windows.Media.Animation.Storyboard.ClockTreeWalkRecursive(Clock currentClock, DependencyObject containingObject, INameScope nameScope, DependencyObject parentObject, String parentObjectName, PropertyPath parentPropertyPath, HandoffBehavior handoffBehavior, HybridDictionary clockMappings, Int64 layer) at System.Windows.Media.Animation.Storyboard.BeginCommon(DependencyObject containingObject, INameScope nameScope, HandoffBehavior handoffBehavior, Boolean isControllable, Int64 layer) at System.Windows.Media.Animation.BeginStoryboard.Begin(DependencyObject targetObject, INameScope nameScope, Int64 layer) at System.Windows.Media.Animation.BeginStoryboard.Invoke(FrameworkElement fe, FrameworkContentElement fce, Style targetStyle, FrameworkTemplate frameworkTemplate, Int64 layer) at System.Windows.StyleHelper.InvokeEventTriggerActions(FrameworkElement fe, FrameworkContentElement fce, Style ownerStyle, FrameworkTemplate frameworkTemplate, Int32 childIndex, RoutedEvent Event) at System.Windows.StyleHelper.ExecuteEventTriggerActionsOnContainer(Object sender, RoutedEventArgs e) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) at Infragistics.Windows.DataPresenter.RecordSelector.OnActivated(RoutedEventArgs args) at Infragistics.Windows.DataPresenter.RecordSelector.RaiseActivated(RoutedEventArgs args) at Infragistics.Windows.DataPresenter.RecordSelector.VerifyActiveState() at Infragistics.Windows.DataPresenter.RecordSelector.OnIsActiveChanged(DependencyObject target, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.RecordSelector.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value) at Infragistics.Windows.DataPresenter.RecordSelector.OnRecordPropertyChanged(Object sender, PropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.RecordSelector.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.ComponentModel.PropertyChangedEventManager.OnPropertyChanged(Object sender, PropertyChangedEventArgs args) at Infragistics.Windows.Helpers.PropertyChangeNotifier.RaisePropertyChangedEvent(String propertyName) at Infragistics.Windows.DataPresenter.Record.OnActiveRecordChanged() at Infragistics.Windows.DataPresenter.DataPresenterBase.OnActiveRecordChange(Record newActiveRecord, Boolean scrollIntoView) at Infragistics.Windows.DataPresenter.DataPresenterBase.SetActiveRecord(Record record, Boolean scrollIntoView) at Infragistics.Windows.DataPresenter.DataPresenterBase.OnCoerceActiveRecord(DependencyObject target, Object value) at System.Windows.DependencyObject.ProcessCoerceValue(DependencyProperty dp, PropertyMetadata metadata, EntryIndex& entryIndex, Int32& targetIndex, EffectiveValueEntry& newEntry, EffectiveValueEntry& oldEntry, Object& oldValue, Object baseValue, CoerceValueCallback coerceValueCallback, Boolean coerceWithDeferredReference, Boolean skipBaseValueChecks) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at Infragistics.Windows.DataPresenter.DataPresenterBase.set_ActiveRecord(Record value) at Infragistics.Windows.DataPresenter.DataPresenterBase.Infragistics.Windows.Selection.ISelectionHost.ActivateItem(ISelectableItem item, Boolean preventScrollItemIntoView) at Infragistics.Windows.DataPresenter.CellValuePresenter.ActivateAndEnterEditMode() at Infragistics.Windows.DataPresenter.CellValuePresenter.ProcessPreviewMouseLeftButtonDown(MouseButtonEventArgs e) at Infragistics.Windows.Editors.ValuePresenter.OnPreviewMouseLeftButtonDown(MouseButtonEventArgs e) at System.Windows.UIElement.OnPreviewMouseLeftButtonDownThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent) at System.Windows.UIElement.CrackMouseButtonEventAndReRaiseEvent(DependencyObject sender, MouseButtonEventArgs e) at System.Windows.UIElement.OnPreviewMouseDownThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
Can anyone suggest whats wrong going on with my application when I try to move my coulmn from grid by default it hides the column and add entry of moved column only in field chooser button....
Thanks.
Got the Issue!
It happens when your recordcontainergenerationmode =Virtual. Then if you try to move your coulmn out of Grid then it get remove but the obove exception has been thorown if you select new record. If you change the Record Generation mode to other then Virtualize then it works fine.
