Hi, I am trying to display a selected value in combobox which is a field of xamdatagrid in hierarichal Visual Tree and the Value I want to display in combobox as selected value is from hierarichal data which is binded with Data Grid. e.g.
Class ABC{ A {get;set;} B {get;set;} C {get;set;}}
Class DataGridDataItem{ X {get;set;} Y {get;set;} BindingList ABC {get;set;}
Class PresenterofDataGrid{ BindnigList<DataGridDataItem> GridSource {get;set;} }
and in Xaml I am doing in this Way..
<igDP:FieldLayout Key="0" > <igDP:Field Name="X" Label="X"/> <igDP:Field Name="Y" Label="Y" /> <igDP:Field Name="ABC" Label="ABC" /></igDP:FieldLayout Key="0" >
<igDP:FieldLayout Key="1" > <igDP:UnboundField Label="ABC" Name="Tenors" DataType="{x:Type NS:ABC}" > <igDP:Field.Settings> <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="SelectedItem" Value="{Binding Path=????}"/> <Setter Property="DisplayMemberPath" Value="A"/> <Setter Property="ItemsProvider" Value="{Binding Source={StaticResource MySource} }" /> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:UnboundField></igDP:FieldLayout Key="0" >
Can Anyone Please suggest the solution. Thanks.
