My application runs fine on most PCs, but on my new tablet PC the performance of the xamdatagrid is very slow - record selection takes 10 seconds and scrolling is next to impossible.
On investigation, it seems that this might be a known problem with WPF and tablets:
http://wpf.codeplex.com/Thread/View.aspx?ThreadId=41964
And in fact there is a hotfix that is supposed to fix it:
http://code.msdn.microsoft.com/KB978520
This works for me on a small test app using the WPF toolkit data grid - the performance is much better, but my app using the xamdatagrid now crashes with the following exception.
Has anyone else had performance problems with tablets? Or with this hotfix?
Any help or advice gratefully recieved!
"Item has already been added. Key in dictionary: 'Infragistics.Windows.Automation.Peers.DataPresenter.CellAutomationPeer' Key being added: 'Infragistics.Windows.Automation.Peers.DataPresenter.CellAutomationPeer'"
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Infragistics.Windows.Automation.Peers.AutomationPeerProxy.GetChildrenCore() at Infragistics.Windows.Automation.Peers.DataPresenter.RecordAutomationPeer.GetChildrenCore() at System.Windows.Automation.Peers.AutomationPeer.EnsureChildren() at System.Windows.Automation.Peers.AutomationPeer.GetChildren() at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.isDescendantOf(AutomationPeer parent) at System.Windows.Automation.Peers.AutomationPeer.ValidateConnected(AutomationPeer connectedPeer) at MS.Internal.Automation.ElementProxy.StaticWrap(AutomationPeer peer, AutomationPeer referencePeer) at System.Windows.Automation.Peers.AutomationPeer.ProviderFromPeer(AutomationPeer peer) at System.Windows.Automation.Peers.AutomationPeer.RaisePropertyChangedEvent(AutomationProperty property, Object oldValue, Object newValue) at System.Windows.Automation.Peers.RangeBaseAutomationPeer.RaiseMaximumPropertyChangedEvent(Double oldValue, Double newValue) at System.Windows.Controls.Primitives.RangeBase.OnMaximumChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.PropertyChangedCallback.Invoke(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value) at System.Windows.Controls.ScrollViewer.OnLayoutUpdated(Object sender, EventArgs e) at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent() at System.Windows.ContextLayoutManager.UpdateLayout() at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg) at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork() at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks() at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at System.Windows.Forms.SafeNativeMethods.MessageBox(HandleRef hWnd, String text, String caption, Int32 type) at System.Windows.Forms.MessageBox.ShowCore(IWin32Window owner, String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon, MessageBoxDefaultButton defaultButton, MessageBoxOptions options, Boolean showHelp) at System.Windows.Forms.MessageBox.Show(String text, String caption, MessageBoxButtons buttons, MessageBoxIcon icon) at Sage.Common.Exceptions.ExceptionManager.HandleUnexpectedException(Exception e) at Sage.MMS.Desktop.DeskTopForm.Main(String[] Args)
I have learned that an issue resulting in a similar stack trace has been fixed in the May 2011 Service Release of 10.1, 10.2, and 10.3....therefore it should also be fixed in 11.1. If you have not already done so, please try the latest Service Release or upgrade to 11.1 and let us know if this issue persist.
The id number for the internal issue is 74791.
