I am displying summary information in the group by row. Do it is displayed as below:
GroupByColumnValue (n items) Summary1, Summary2
By Default summary is displayed seperated by comma and this is a string.
I want to style this information in such a way that GroupByColumnValue is in different foreground color, summary1 is in different color and summary2 is in different color.
I looked at GroupByArea Style but could not find a way to style this text, as this whole text is treated a single string.
ah, too early to conclude, eventually the converter gets the values, it is working fine. Thanks.
Hi Vlad,
Thanks for this, I tried your solution I got summaries values in the converter but did not get values of the column. So converter is getting below value.
"System.Data.DataView (0 items) Filled 0, AvgPx = .0000"
Instead of group by value it is showing System.Data.DataView, is there any way to get this in the converter and apply color based on that?
Naveen
You might achive this using a converter for the content of the GroupByRecord where you can split the string to a collection of Run elements. You can then set different Foreground colors. Please check out the attached sample project for more details.
