370
XamDataGrid HyperLinkCell and Command implementation in MVVM
I have a XamDataGrid with a hyperlink cell. I'm trying to bind the Command on the Hyperlink cell to the command in the ViewModel, but having difficulty doing that.
Below is the XAML for the XamDataGrid
<ig:XamDataGrid DataSource="{Binding Report}" Theme="Office2k7Black" Height="600" Width="auto" ActiveDataItem="{Binding ActiveException, Mode=TwoWay}">
                        <ig:XamDataGrid.Resources>
                            <Style TargetType="{x:Type ig:CellValuePresenter}" x:Key="hyperlinkCell">
                                <Setter Property="Template">
                                    <Setter.Value>
                                        <ControlTemplate TargetType="{x:Type ig:CellValuePresenter}">
                                            <TextBlock Margin="{TemplateBinding Padding}">
                                                <Hyperlink NavigateUri="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}" Command="{Binding LoadDetailReport}">
                                                    <TextBlock Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}">
                                                    </TextBlock>
                                                </Hyperlink>
                                            </TextBlock>
                                        </ControlTemplate>
                                    </Setter.Value>
                                </Setter>
                            </Style>
                        </ig:XamDataGrid.Resources>
                        <ig:XamDataGrid.FieldLayoutSettings>
                            <ig:FieldLayoutSettings AutoGenerateFields="False"/>
                        </ig:XamDataGrid.FieldLayoutSettings>
                        <ig:XamDataGrid.FieldSettings>
                            <ig:FieldSettings AllowFixing="NearOrFar" AllowEdit="False" Width="auto" Height="auto"  />
                        </ig:XamDataGrid.FieldSettings>
                        <ig:XamDataGrid.FieldLayouts>
                            <ig:FieldLayout>
                                <ig:FieldLayout.Fields>
                                    <ig:Field Name="Division" Label="Division">
                                        <ig:Field.Settings>
                                            <ig:FieldSettings  AllowResize="False" />
                                        </ig:Field.Settings>
                                    </ig:Field>
                                    <ig:Field Name="Cluster" Label="Cluster" />
                                    <ig:Field Name="Productline" Label="Product Line" />
                                    <ig:Field Name="Mainbook" Label="Risk Group" Visibility="Collapsed"/>
                                    <ig:Field Name="Subbook" Label="Sub Book" Visibility="Collapsed"/>
                                    <ig:Field Name="Cobdate" Label="Cob Date"/>
                                    <ig:Field Name="TotalTrades" Label="Total Trades">
                                        <ig:Field.Settings>
                                            <ig:FieldSettings CellValuePresenterStyle="{StaticResource hyperlinkCell}"/>
                                    </ig:Field>
                                    <ig:Field Name="TotalExceptions" Label="Total Exceptions"/>
                                    <ig:Field Name="LiveTradesWithoutPVs" Label="Live Trades Without PVs"/>
                                    <ig:Field Name="ZeroPVCount" Label="Zero PV Count">
                                        <ig:Field.Settings>
                                    </ig:Field>
                                    <ig:Field Name="StalePVCount" Label="Stale PV Count"/>
                                    <ig:Field Name="RegressedPVCount" Label="Regressed PV Count"/>
                                    <ig:Field Name="TotalExceptionsValidated" Label="Total Exceptions Validated"/>
                                    <ig:Field Name="TotalExceptionsNotValidated" Label="Total Exceptions Not Validated"/>
                                </ig:FieldLayout.Fields>
                            </ig:FieldLayout>
                        </ig:XamDataGrid.FieldLayouts>
                    </ig:XamDataGrid>
This is the error I see in the output window
System.Windows.Data Error: 39 : BindingExpression path error: 'LoadDetailReport' property not found on 'object' ''DataRecord' (HashCode=15172893)'. BindingExpression:Path=LoadDetailReport; DataItem='DataRecord' (HashCode=15172893); target element is 'Hyperlink' (HashCode=57769674); target property is 'Command' (type 'ICommand')
From the error, I'm assuming that the parent DataContext which is the ViewModel is not visible to the Cell in which I have the hyperlink,
Can anybody give me some direction on this. Any help very much appreciated.
Shravan
