115
Second Headerline
Hi
I want a second headerline where I can summarize my underlaying fields....
For example i want
           Hook
Utilization | Stress
Here the "Hook" should be static inside the header (with a columnspan=2), but without any information inside the datacontent...
Here's what I got at the moment:
Dim hookField As New UnboundField With {.Label = "Hook", .Column = 0, .ColumnSpan = 2, .Row = 0, .RowSpan = 1, .Height = New FieldLength(0),.IsExpandable = False}
Dim hookUtilizationField As New Field With {.Name = "HookUtilization", .Label = "Utilization", .Column = 0, .Row = 1}
Dim moduleStressField As New Field With {.Name = "ModulStress", .Label = "Modul Stress", .Column = 1, .Row = 1}
e.FieldLayout.Fields.Add(hookField)
e.FieldLayout.Fields.Add(hookUtilizationField)
e.FieldLayout.Fields.Add(moduleStressField)
With this solution the UnboundField Hook will be shown a bit inside every row of the content area...
Any ideas how can i solve that?
  • 69686
    Verified Answer
    You should set the CellContentAlighment property of the Field to LabelOnly in order to remove its cell representation and leave only the header. You can see a walkthrough and a sample with this here.
