I was looking at the XamFeatureBrowser for WPF 2010 Volume 2 and it doesn't seem to show off any of the new controls?
Oh - I thought the new controls were also available for .NET 3.5. I must have missed that in the "what's new" section. We'll still be using 3.5 at work for a while, and even once 4.0 is deployed enterprise-wide I'm not sure we'll be upgrading the VS solution to 2010/4.0 right away.
Thanks!Michel
Hi Michel,
Do you have Visual Studio 2010 installed? The new 4.0 assemblies as well the samples for them (the new controls are in 4.0) are installed only if you have Visual Studio 2010 installed on your system.
You can take a look here - http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=WPF_Dot_Net_4_Builds.html
Also after installing Visual Studio 2010 you should reinstall the samples so that the samples for 4.0 are correctly installed.
Greetings,
Horen Kirazyan
