932
field.Settings.ResetCellWidth() and field.Settings.ResetLabelWidth() are removed in v10.1
Hi, I was using field.Settings.ResetCellWidth() and field.Settings.ResetLabelWidth() to set column width based on user action in v9.1, I am trying to upgrade to v10.1 and see these methoda are no longer there!!!
Below is what I was doing, without using Reset Cell and Label width setting width does not work!!
            foreach (FieldLayout fieldLayout in grid.FieldLayouts)
              foreach (Field field in fieldLayout.Fields)
                string text;
                if (widths.TryGetValue(field.Name, out text))
                  FormattedText formattedText = new FormattedText(text, CultureInfo.CurrentCulture, grid.FlowDirection, dualGridTypeface,
                                                    grid.FontSize * (double)grid.GetValue(DualGridViewZoom.ZoomProperty), grid.Foreground);
                  double width = formattedText.BuildGeometry(new Point()).Bounds.Width;
                  //field.Settings.ResetCellWidth();
                  //field.Settings.ResetLabelWidth();
                  field.Settings.CellWidth = field.Settings.LabelWidth = width;
Can some one from infragsitcs comment? are there any alternatives?
  • 3520
    Hi meetnd,
    In v10.1 what you can use, instead of CellWidth and LabelWidth, is the Width property of the field.
    Something like:
    field.Settings.ClearValue(
    Field.WidthProperty);
    field.Settings.Width =
    new FieldLength(18);
    Please let us know if this works for you.
    Thanks.
