45
Using WindowsFormsHost in the XamRibbon in a MenuTool
I´m trying to use a WindowsFormsHost in a MenuTool in the Ribbon Control, but the WindowsFormsControl is not displayed. (If I place the WindowFormsHost under the RibbonGroup it is working correct.)
Here is a code sample (a reference to WindowsFormsIntegration and System.Windows.Forms must be set in the project settings):
xmlns
:winform="clr-amespace:System.Windows.Forms;assembly=System.Windows.Forms"
<igRibbon:XamRibbon>
 <igRibbon:RibbonTabItem Header="Start">
   <igRibbon:RibbonGroup Caption="Test">
     <igRibbon:MenuTool Width="100">
       <WindowsFormsHost Width="100" Height="50" Background="LightBlue"
           Margin="3">
              <winform:Button Text="TestButton" ></winform:Button>
       </WindowsFormsHost>
     </igRibbon:MenuTool>
           Margin="3">
     </WindowsFormsHost>
</igRibbon:RibbonGroup>
</igRibbon:RibbonTabItem>
Parents
No Data
Reply
  • 138253
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. So I have been looking through your post and I created a sample project for you. I basically create a template for a CustomTool class in which a put a WindowsFormsHost with a Button inside. I did that because in the MenuTool of the XamRibbon you can put only tool elements and if you want to put a custom control you can implement IRibbonTool interface and create the custom tool.
    Feel free to write me if you have any other questions.
    XamRibbonWindowsFormsHost.zip
Children
No Data
