1485
Preserve "default" row height in a control template
I'm using the following control template to display an icon on the left of some text when necessary.  I just noticed that when I use it, the row height is a few pixels short of what it is by default, so characters with descenders such as "y" are partially truncated (the lower part of the "y" is not displayed, for example.)  What do I need to do to this control template to resolve this?
                <Style x:Key="WarningIconCellStyle" TargetType="{x:Type igDP:CellValuePresenter}">
                    <Setter Property="Template">
                        <Setter.Value>
                            <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
                                <StackPanel Orientation="Horizontal">
                                    <!-- Give the left edge of the cell a vertical line. -->
                                    <Border
                                        BorderBrush="#FFEEEEEE"
                                        BorderThickness="1,0,0,0"
                                    <Image
                                        x:Name="WarningIcon"
                                        Source="Images\icons\warning_16x16.png"
                                        Stretch="Fill"
                                        HorizontalAlignment="Center"
                                        VerticalAlignment="Center"
                                        Width="16"
                                        ToolTipService.ShowDuration="60000"
                                        ToolTipOpening="WarningIcon_ToolTipOpening"
                                        Height="16">
                                        <Image.ToolTip>
                                            <StackPanel
                                                <Image
                                                   Source="Images\icons\warning_48x48.png"
                                                   Stretch="Fill"
                                                   Width="48"
                                                    Height="48"
                                                <TextBlock
                                                    Margin="5,5,5,5"
                                                    MaxWidth="300"
                                                    TextWrapping="Wrap"
                                                    Text="{Binding Path=DataItem.WarningText}"/>
                                            </StackPanel>
                                        </Image.ToolTip>
                                    </Image>
                                    <Label
                                        x:Name="PhraseField"
                                        Content="{Binding Path=DataItem.Phrase}"
                                </StackPanel>
                                <!-- Hide the warning icon if there is no warning for the phrase -->
                                <ControlTemplate.Triggers>
                                    <DataTrigger Binding="{Binding Path=DataItem.HasWarning}" Value="False">
                                        <Setter TargetName="WarningIcon" Property="Visibility" Value="Collapsed" />
                                    </DataTrigger>
                                </ControlTemplate.Triggers>
                            </ControlTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
Michel
  • 1485
    Verified Answer
    D'OH!  Never mind, I had done this before, just forgotten all about it.  I added this to the Label's property:
                                            Width="{TemplateBinding Width}"
                                            Height="{TemplateBinding Height}"
                                            Margin="0,0,0,0"
                                            Padding="0,0,0,0"
