165
If value is 0 then display blank
I have written an Ivalueconverter that will convert any double or integer into an empty string if the value is 0.
I just can't figure out how to apply it.
    <Window.Resources>
        <controls:DisplayZeroAsBlank x:Key="DisplayZeroAsBlank"/>
    </Window.Resources>
            <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="zero">
                <Setter Property="Value">
                    <Setter.Value>
                        <Binding Converter="{StaticResource DisplayZeroAsBlank}"></Binding>
                    </Setter.Value>
                </Setter>
            </Style>
                            <igDP:Field Name="OurAsk">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings CellValuePresenterStyle="{StaticResource zero}" />
                                </igDP:Field.Settings>
                            </igDP:Field>
How should this be done?
  • 69686
    Suggested Answer
    If you want to display an empty string when a value is zero, it is best to use an IValueConverter and apply it at the ValueToDisplayTextConverter property of the editor. You can create a style for the editor of the specific field and apply it at the Field -> Settings -> EditorStyle property. Another way would be to apply the converter to the Converter property of the Field.
