94
Headers gone when using ExpansionIndicatorDisplayMode
I have a grid with nested records and I would like to display the expansion indicator only if there is subrecords. So I used the following option : ExpansionIndicatorDisplayMode="CheckOnDisplay".
Problem : when I set the indicator, headers are gone. If I do not so, headers are well displayed.
with ExpansionIndicatorDisplayMode="CheckOnDisplay" :
without the option :
Do you any idea to slove the problem?
Thank you
Guillaume
  • 94
    posted in reply to John Doe
    Here is the xaml code I uses. It is more or less the same than the one used to display a data grid as a tree
            <igDP:XamDataGrid Name="xamDtaGridPlanFi" GroupByAreaLocation="None" DataSource="{Binding PlanFi.Nodes}" FieldChooserOpening="xamDtaGridPlanFi_FieldChooserOpening">
                <igDP:XamDataGrid.Resources>
                    <converters:XamConverter x:Key="conv"/>
                    <Style x:Key="{x:Type igDP:FieldChooser}" TargetType="{x:Type igDP:FieldChooser}" BasedOn="{StaticResource {x:Type igDP:FieldChooser}}">
                        <Setter Property="FieldDisplayOrder" Value="SameAsDataPresenter" />
                    </Style>
                    <Style TargetType="{x:Type igDP:RecordPresenter}">
                        <Setter Property="IsExpanded" Value="True"/>
                    </Style>
                    <Style TargetType="{x:Type igDP:DataRecordPresenter}" x:Key="nestedEXPStyle">
                        <Setter Property="RenderTransform">
                            <Setter.Value>
                                <TranslateTransform X="{Binding Path=NestingDepth, Converter={StaticResource conv}}" Y="0"/>
                            </Setter.Value>
                        </Setter>
                    </Style>
                    <Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key="nestedCVPStyle">
                        <Setter Property="Margin" Value="{Binding Path=NestingDepth, ConverterParameter=cvp, Converter={StaticResource conv}}" />
                    </Style>
                    <Style TargetType="{x:Type igDP:LabelPresenter}">
                        <EventSetter Event="SizeChanged"  Handler="OnLabelPresenterSizeChanged" />
                    </Style>
                </igDP:XamDataGrid.Resources>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout Key="master">
                        <igDP:Field Name="Label">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings CellWidth="260" />
                            </igDP:Field.Settings>
                        </igDP:Field>
                        <igDP:Field Name="Qty"/>
                        <igDP:Field Name="Value"/>
                        <igDP:Field Name="Nodes"/>
                        <igDP:FieldLayout.Settings>
                            <igDP:FieldLayoutSettings HeaderPrefixAreaDisplayMode="FieldChooserButton" HeaderPlacement="OnTopOnly" HeaderPlacementInGroupBy="OnTopOnly"/>
                        </igDP:FieldLayout.Settings>
                    </igDP:FieldLayout>
                    <igDP:FieldLayout Key="nested">
                                <igDP:FieldSettings CellValuePresenterStyle="{StaticResource nestedCVPStyle}"/>
                        </igDP:Field>
                        <igDP:FieldLayout.FieldSettings>
                            <igDP:FieldSettings AllowResize="False"/>
                        </igDP:FieldLayout.FieldSettings>
                            <igDP:FieldLayoutSettings ExpansionIndicatorDisplayMode="CheckOnDisplay" HighlightAlternateRecords="True" DataRecordPresenterStyle="{StaticResource nestedEXPStyle}" LabelLocation="Hidden"/>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings AutoGenerateFields="False"/>
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldSettings>
                    <igDP:FieldSettings AllowEdit="False" CellClickAction="SelectRecord"/>
                </igDP:XamDataGrid.FieldSettings>
            </igDP:XamDataGrid>
    Guillaume
  • 69686
    Hello Guillaume,
    This looks like a styling issue as from what I can see from the screenshots, the LabelPresenters are gone, however the header record is there.  How are you setting the ExpansionIndicatorDisplayMode property? Are you using some style?
