I would like to set mandatory field backgrounds are red and others are green. So I try to implement below. But I could not control ValueConstraint Nullable property with trigger. Could you help please ?
<Window x:Class="TriggerGirilmesigerekenalanlar.Window1" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:y="http://infragistics.com/Editors" Title="Window1" Height="300" Width="300"> <Window.Resources> <Style TargetType="{x:Type y:XamTextEditor}"> <Style.Triggers> <Trigger Property="ValueConstraint" Value="{x:Null}"> <Trigger.Setters> <Setter Property="Background" Value="green"></Setter> </Trigger.Setters> </Trigger> <Trigger Property="y:ValueConstraint.Nullable" Value="false"> <Trigger.Setters> <Setter Property="Background" Value="red"></Setter> </Trigger.Setters> </Trigger> </Style.Triggers> </Style> </Window.Resources> <StackPanel> <y:XamTextEditor> <y:XamTextEditor.ValueConstraint> <y:ValueConstraint Nullable="False" ></y:ValueConstraint> </y:XamTextEditor.ValueConstraint> </y:XamTextEditor> <y:XamTextEditor></y:XamTextEditor> </StackPanel> </Window>
Thank you
You cannot access the Nullable property of the ValueConstraint like that. However, you can create a DataTrigger and try with it, like so :
<DataTrigger Binding="{Binding Path=ValueConstraint.Nullable, RelativeSource={RelativeSource Self}}" Value="false">
<DataTrigger.Setters>
</DataTrigger.Setters>
</DataTrigger>
