1080
Programmatically select child record
I'm using Version 9.2.20092.2049.
I have a hierarchical XamDataGrid with Parent and Child records (Hierarchy has only two levels).If I've select a record on the first level, I can set it active by
xamMyDataGrid.Records[ParentRecordIdx].IsActive = true;
xamMyDataGrid.BringRecordIntoView(xamMyDataGrid.Records[ParentRecordIdx]);
If I want to select a child record do it in a similar way by calling
xamMyDataGrid.Records[ParentRecordIdx].ViewableChildRecords[ChildRecordIdx].IsActive = true;
xamMyDataGrid.BringRecordIntoView( ....
But this time the record is not selected. The background color is not changed and the triangle on the left is missing.
Do child record need special treatment? What could be the cause of the problem?
Thanks in advance for all answers.
Markus
