how works ExpandableFieldRecordHeaderDisplayMode property?because I have set it to NeverDisplayHeader but has not had any effect on the expandable record header and also changing the value, my datagrid always behaves the same way
Thanks for replyMatteo
I have a problem with sync widths of fields between parent and child layouts.It seems, the approach above is not working properly, when AutoFit is enabled for the grid.
My version of Infragistics controls is 13.1.
Can someone give an advice or an example of how it can be solved?
Yes, that is possible. You could bind the width of the top level field to the nested field. A sample implementation you can find here by Josh Smith.
Thanks, Alex. That worked.
I wanted to try another possibility, to make the grid more tree like: Is it possible to bind the child row indentation to the width of a column in the parent row. eg, if I expand column 0 in the parent row, the child rows move to the right.
You can see how to remove the indentation here.
Thanks. That did it. A follow up question: How do I control (eg set to 0) the spacing marked in red. I've tried templating the ExpandableFieldRecordPresenter, the RecordListControl. I've tried setting Padding and/ or Margin to 0 for the ExpandableFieldRecordPresenter. No luck.
