Object reference not set to an instance of an object. at Infragistics.Windows.Ribbon.QuickAccessToolbarPanel.RemoveVisualChildren() at Infragistics.Windows.Ribbon.QuickAccessToolbarPanel.OnIsItemsHostChanged(Boolean oldIsItemsHost, Boolean newIsItemsHost) at System.Windows.Controls.Panel.OnIsItemsHostChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidatePropertiesOnTemplateNode(DependencyObject container, FrameworkObject child, Int32 childIndex, FrugalStructList`1& childRecordFromChildIndex, Boolean isDetach, FrameworkElementFactory templateRoot) at System.Windows.StyleHelper.ClearTemplateChain(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, List`1 templateChain, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.ClearGeneratedSubTree(HybridDictionary[] instanceData, FrameworkElement feContainer, FrameworkContentElement fceContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate) at System.Windows.Controls.Control.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents) at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle) at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache) at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.FrameworkElement.UpdateStyleProperty() at System.Windows.TreeWalkHelper.InvalidateOnTreeChange(FrameworkElement fe, FrameworkContentElement fce, DependencyObject parent, Boolean isAddOperation) at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent) at System.Windows.FrameworkElement.RemoveLogicalChild(Object child) at Infragistics.Windows.Ribbon.XamRibbon.VerifyParts() at Infragistics.Windows.Ribbon.XamRibbon.OnApplyTemplate() at System.Windows.FrameworkElement.ApplyTemplate() at Microsoft.Expression.Platform.WPF.WpfViewNodeManager.EnsureElementInDictionary(Object root, ViewNode knownAncestor)
My code is:
<igRibbon:XamRibbonWindow x:Class="Ribbon.Window1" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" Title="Window1" Height="300" Width="300" xmlns:igRibbon="http://infragistics.com/Ribbon"> <igRibbon:RibbonWindowContentHost> <igRibbon:RibbonWindowContentHost.Ribbon> <igRibbon:XamRibbon Theme="Office2k7Silver"> <igRibbon:XamRibbon.QuickAccessToolbar> <igRibbon:QuickAccessToolbar> <igRibbon:QatPlaceholderTool /> <igRibbon:QatPlaceholderTool /> <igRibbon:QatPlaceholderTool /> </igRibbon:QuickAccessToolbar> </igRibbon:XamRibbon.QuickAccessToolbar> </igRibbon:XamRibbon> </igRibbon:RibbonWindowContentHost.Ribbon> </igRibbon:RibbonWindowContentHost></igRibbon:XamRibbonWindow>
The problem happens as soon as I put the Theme property in the Ribbon.
As soon as I remove it, the problem is gone.
I've removed the TargetID from the QuickAccessToolbar to reduce the code. This is just a demo project to show the problem.
It seems that the toolbar is throwing the exception at infragistics.Windows.Ribbon.QuickAccessToolbarPanel.RemoveVisualChildren()
I'm using Infragistics NetAdvantage 2010 Vol 1 with the SR or 02-April 2010
Thank you.
This issue was fixed and the service release was just published. You should be able to download it.I hope this helps.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Thank you :-)
I was able to reproduce the issue. It should be addressed in the next hotfix.
The code I gave should make your Visual Studio throw the designer exception,
I've only tested it with Visual Studio 2010. I don't know if it also happens with 2008.
Hi!
I have the same problem. It is in the design view in VS 2010 (Version 10.0.30319.1 RTMRel). I'm also sure that the theme is the problem. Because any changes to the theme property removes the problem.
Sincerely,
voks
