380
Enumerator is not valid because the collection changed.
I am embedding a 2D Line Chart, XamChart in a user control, which builds fine, but when I embed that control in another - the parent control and all subsequent parent controls fail in Expression Blend with a 'The enumerator is not valid because the collection changed.' error.
I'm using code directly copied from the feature browser, with relative links fixed, and am assigning datapoints in the C# code behind.
If I build the project from Visual Studio, the project will run and the chart works correctly. But I can not edit any of the parent controls in Expression blend.
I found only one post that touched on this issue:
http://forums.infragistics.com/forums/p/24390/100889.aspx#100889
..and no resolution was ever posted.
Has this issue been looked into? Are there any resolutions?
