1325
Focusing problem
I'm creating custom control derived from ComboBox that has Intellisense-like feature. When user presses Ctrl+Space popup is shown. I've got 2 types of popup: one with a listbox inside and second with XamMonthCalendar. When popup is opened I'm moving focus to ListBox or XamMonthCalendar by calling Focus() method so user can select value by using keyboard. In case with ListBox it works fine, but with with XamMonthCalendar it doesn't - control doesn't receive focus.
Popups are defined in xaml in the same way:
<Popup x:Name="PART_PopupKeywordList" Grid.Column="0" AllowsTransparency="True" Placement="Bottom" IsOpen="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=IsKeywordDropDownOpen}" StaysOpen="False"
PopupAnimation="{DynamicResource {x:Static SystemParameters.ComboBoxPopupAnimationKey}}" Focusable="False">
<luna:SystemDropShadowChrome Color="Transparent">
<Border Background="{DynamicResource {x:Static SystemColors.WindowBrushKey}}"
BorderBrush="{DynamicResource {x:Static igres:RibbonBrushKeys.SubMenuHeaderPopUpBorderDarkFillKey}}"
BorderThickness="1" CornerRadius="2,2,2,2" SnapsToDevicePixels="True" HorizontalAlignment="Stretch"
VerticalAlignment="Stretch" Width="Auto" Height="Auto">
<ListBox x:Name="PART_ListBoxKeywordList" BorderBrush="Transparent" Margin="0,0,4,0"
KeyboardNavigation.DirectionalNavigation="Cycle" FocusVisualStyle="{x:Null}"/>
</Border>
</luna:SystemDropShadowChrome>
</Popup>
<Popup x:Name="PART_PopupMonthCalendar" Grid.Column="1" AllowsTransparency="True" Placement="Bottom" PopupAnimation="{DynamicResource {x:Static SystemParameters.ComboBoxPopupAnimationKey}}" StaysOpen="False" Focusable="False">
<igmc:XamMonthCalendar x:Name="PART_MonthCalendar" SelectionType="Single" AutoAdjustCalendarDimensions="False"/>
</Border>
</Popup>
In the code I subscribe to a Popup.Opened event:
private void KeywordPopup_Opened(object sender, EventArgs e)
     // keywordList is a ListBox
     if (_keywordList != null)
             _keywordList.Focus();
private void MonthCalendarPopup_Opened(object sender, EventArgs e)
        // _monthCalendar is a XamMonthCalendar
        if (_monthCalendar != null)
              _monthCalendar.Focus();
