190
CellClick event in XamDataGrid?
I have a grid with 2 columns. One is read only and second is not.
The second is a checkbox column. Initially, FieldSettings.CellClickAction has the default value.
So when I click on checkbox column, I can check/uncheck  the checkbox.
I want when to click on first column (the read-only), the whole row to be selected ( FieldSettings.CellClickAction = CellClickAction.SelectRecord.)
If I set initially CellClickAction.SelectRecord, then I cannot check/uncheck the second column, only if I make a double-click on the checkbox and then everything is ok.
This is not acceptable. What I'm need?
Please give me a solution.
I thought that exist a CellClick event to catch the clicked cell, but I don't see something usefully.
Regards, Liviu
  • 8576
    Hi Liviu -
    Here is a post that shows how to handle the PreviewMouseLeftButtonDown event and detect when you are over a particular field (column): http://forums.infragistics.com/forums/p/2784/16536.aspx#16536
    So what you should be able to do is:
    • set the CellClickAction to SelectRecord
    • listen to the PreviewMouseLeftButtonDown event and look for a click on a cell in the column with the checkboxes as shown in the code from the above referenced post
    • toggle the boolean value of the
    • if you want you can mark the event handled at this point to prevent the grid from selecting the record
    Joe
