Hi, I'm evaluating the ribbon control and have two quick questions regarding it:
1. Is it possible to set the visibility/opacity of the ribbon control to 0, and JUST show the ApplicationMenu and QAT?
2. Is there a color picker included with the ribbon control? Most of the samples have an icon associated with it but no dialog popup for it.
Thank you, glad you attached it because I can't find it in the intalled examples.
Thanks again!
Hi -
The sample source code is copied to your system during the NA install process. If you're having trouble finding it, I have attached a zip with the C# and VB versions of the source.
Enjoy!
JoeM
Hello I'm having the same problem where can I find the Ribbon with RichTextBox sample code?
Thanks.
Re-template the entire Ribbon (!!!) -or- If you dont mind having some empty space below the QAT (since the app menu spans the QATand the tab header area), you can: set the IsMinimized to True (to hide the ribbon group area) set AllowMinimize to False (to prevent the end user from unminimizing it) add 1 RibbonTabItem whose Visibility is Hidden (so there is something there to give the area in the second row some height since it is the xamTabControl that is providing that background).
