506
XamDateTimeEditor
I've a XamDateTimeEditor binded to a string property that contain the date.
But when the DataContext is loaded, if the string is empty the field contains the date 01/01/0001.
I want an empty field.
How can I set this behavior?
Thks.
Sacha
  • 27093
    I have been looking into this for you and did replicate the behavior you described.  This can be overcome by creating a converter of your own and setting it to the XamDateTimeEditor’s ValueToDisplayTextConverter property. I did some more research and was able to create a converter for you to achieve your goal:
        public class DTtoString : IValueConverter
            public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                if (value != null)
                    DateTime temp = new DateTime();
                    if (DateTime.TryParse(value.ToString(), out temp))
                        if (temp == (parameter as XamDateTimeEditor).ComputedMinDate)
                            return null;
                        return temp.ToString(culture);
                    return null;
                else return null;
            public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
                return value;
    Please let me know if I can assist you further on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
